Identifying a quadrajet part
https://webdisk.ucalgary.ca/~jmknopp..._html/carb.jpg
What's the yellow arrow pointing to? I'm just curious what that thing is next to the electric choke.
primary choke pull-off diaphragm
it has 2 jobs: to crack the choke open a little bit at cold start-up, and to control the opening of the scondary air valve
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
It's a design feature. Other carbs use different methods to do that job.
hey, my webspace being used for good, and not evil. Rock on.
LT1Formula
20
Nov 14, 2015 12:02 AM
