1985 z-28 carb advice
hey yall i have a 85 z-28 with the stock carb i was woundering what would be a good replacement for this as far as size and brand i would like for it to be very streetable but a little power. also what is the intake on the car and would anyone have any ideals about replacing it also thank you for any info Fred
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Neither of those would be a good way to spend your money. You'd spend ~$500, and get maybe a handful of HP. Bad $/HP ratio there.
Welcome to the forum. Now go get headers and full exhaust, and subframe connectors. Then come back
fastest header fix would be either hooker or hedman shorty made for the camaro with y pipe include. That is if you have factory correct exhaust. If you still have your factory cat on i would also check out a high flow cat to free up some ponnies.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
DR secondary rods, B hanger, add 6 degrees base timing, hooker 2055s...
...to get u started anyways
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Tobias05
DR secondary rods, B hanger, add 6 degrees base timing, hooker 2055s...to get u started anyways
JamesC
Transmission: 4L80E/4L80E
Hanger bracket? Do you mean rod hanger? If so, that's part of the secondary system on the carb.
Originally Posted by 85whitez-28
is the dual snorkle the one that comes off a ho 305?
JamesC
theshackle
Mar 5, 2017 06:37 PM
louishenry
Aug 28, 2015 09:41 AM
