bogs
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
bogs
i have a freshly rebuilt 350 bored .30 882 heads roller rockers 440 lift cam on the intake and exhaust. and a 650 holley dp it drives fine but as soon as i floor it or kick the secondarys in it just dosent want to go anywhere like its boging. what could it be thanks
Transmission: 4L80E/4L80E
Any opening of the secondaries at all, even slowly opening them?
Have you checked the secondary bowl fuel level?
Car: 1987 iroc z
yes the secondarys open all the way and im pretty sure the fuel is right it dribbles out of the sight plug.
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Have you checked your secondary pump shot? The bog comes from not getting enough fuel, when the secondary opens quickly the AIR atomizes and goes to the sides of the cylinker walls and you get a lean condition, that second shot mixes with the air and restores the correct A/F ratio. It a notorious problem for the big secondarys on Quadra Boggs.....The best thing is it is so much easyer to cure on a Holley.
Let me restate my question: Do you have a problem whenever the secondaries are open at all, or just when you first go WOT? For instance, if you give it just enough throttle to start opening the secondaries, does it bog down on you?
Trying to establish whether you have a secondary main circuit problem, or as suggested by the other reply, an accelerator pump circuit problem.
RedLeader289
May 28, 2019 01:47 PM
