Holley or Edelbrock??
Old Jun 28, 2006 | 10:06 PM
txcamaro's Avatar
Car: '86 Camaro Z-28
Engine: 305 V8
Transmission: 5-Speed standard
I've got an 86 with a 305, Holley Street Dominator intake, and Edelbrock 795cfm carb. Can't remember part # on carb, bit it's the Qjet replacement. I've had minor tuning problems, but it seems fine now. Problem seems to be in the choke, but i'm not too worried. I was thinking about a smaller carb though. Somewhere in the neighborhood of a 600 or a 650, but don't know if I should go with a Holley or Edelbrock. I hear pro's and con's for both from my friends. Just thought I'd get some extra input. Are the Holley's that hard to keep tuned?? Any info would be helpful. Thanks.
Old Jun 28, 2006 | 10:22 PM
ohiothirdgen's Avatar
If your looking for bolt on and go id probably get an edelbrock. Holley has the street avenger that is like that. I have a 660 holley sa on my iroc and it is pretty horrible. I really dont recommend it at all.
Old Jun 29, 2006 | 07:55 AM
'86 350's Avatar
Car: '86 Camaro SC
I had a 670 street avenger, and I didn't like it at all. I sold it for an Edelbrock Performer 600 and jetted that up. While the Edelbrock is better then the Street Avenger ever was, I still wish I had gone with a carb with Mechanical Secondaries, espescially in my 5 speed.
If I were you I'd go with something like a 600 DP.
Old Jun 29, 2006 | 08:00 AM
contact's Avatar
Engine: sbc 350
'dominator intake', is different than a stardard flange?
not sure if that is an issue.
both brands of carbs need tuning, to operate
their best. both brands have their advocates.
Edels use metering rods instead of a power valve,
superior, IMO.
Edels use primaries, that are smaller than the secondaries,
IMO, superior for a street car
Holley people contend that the 'air demand valve' in the Edels can cause a delay in the opening of
the secondaries. You have to decide for yourself
how important that is.
If you decide on Edel, consider the Thunderer series
with spring-adjustable air valve, better IMO.
Old Jul 10, 2006 | 06:29 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
i was thinking about getting the holly street avenger and i was wanting to know what u dident like about it
Old Jul 10, 2006 | 08:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Bigger than a 305 needs, basically an over-priced Holley vacuum secondary. SA's are made for marketing, not performance.
Old Jul 10, 2006 | 08:47 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yeah, the street avenger sucks. if all you want is drivability, then just run an edelbrock 1406, which is the 600cfm version. if performance is what you are looking for, then a 600 holley double pumper is in order here. don't even bother with the holley vacuum secondary carbs.
Old Jul 10, 2006 | 08:59 PM
txcamaro's Avatar
Engine: 305 V8
i've decided to go with the edelbrock 1406. haven't ordered it yet, but i'm going to try and get it some time next week. i'm hoping the 600 will give me a little better performance than the 795 which i think is too big for the motor that's there. i'm also hoping to score a couple mpgs. everyone i talk to about the holley's say it's hard to keep it tuned properly and i don't want to be under the hood every weekend on my daily driver.
Old Jul 11, 2006 | 01:31 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
is the edelbrock like the street avenger just bold on and go???
Old Jul 11, 2006 | 01:37 PM
mw66nova's Avatar
Engine: 7.0L
pretty much.
Old Jul 11, 2006 | 09:21 PM
five7kid's Avatar
Technically, that is completely untrue. The two carbs use completely different concepts to accomplish the same operations.
Practically, the two carbs are both demand-based secondaries (although the way they operate to "demand" is completly different). What it comes down to, is this: If you don't get a Holley double-pumper, keep the q-jet. The primaries are smaller than either the Holley or Performer, the secondaries are demand-based pretty much like the Performer, and it will be no "bigger" than the engine needs when you floor it.
Old Jul 11, 2006 | 11:03 PM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
well witch one would be better for punch it and go power
Old Jul 12, 2006 | 09:55 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Having used both the Qjet and Edelbrock I'd say six of one and half a dozen of the other. Qjets are truly excellent when tuned correctly. 1406s also deliver really nice performance. One thing I have noticed is that the 1406 is more consistent in the mpg it delivers. The Qjet is fine there, too, but seemed to vary somewhat more than my current 1406.
If I already had a Qjet then I'd stick with it because the 1406 is not superior in performance or mpg.
Old Jul 12, 2006 | 07:18 PM
txcamaro's Avatar
Engine: 305 V8
so you're saying my mpgs won't change between the 795 cfm and the smaller 600 cfm i'm thinking about getting??
Old Jul 12, 2006 | 07:44 PM
mw66nova's Avatar
Engine: 7.0L
it's possible since the larger booster signals will require more fuel, even on a smaller cubic inch motor.
Old Jul 12, 2006 | 08:43 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
A little late but I have the Holley 670 carb and I HATE IT!!! I couldn't tune it for chit and I would rather have a QJ or an Edelbrock. My carb is still basically brand new, I didn't choose it but is really SUCKS!!!
Old Jul 12, 2006 | 09:49 PM
CG_1985_Z28's Avatar
Car: 1985 Z28 camaro
Engine: lq4
Transmission: th350
holley or edelbrock
i used a edelbrock 650 on my car, i bought it from summit for about 250 or 260 dollars and it worked great right out of the box and is still working with no problems. Bolt it on and go!
Old Jul 12, 2006 | 10:24 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Wierd you guys are all hating the street avenger, I have it , put the jets my engine guy said to run into it, played with the vacuum secondary springs a bit and never touched it again and it still runs perfect since 2002,
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
