Air cleaner with a holley 4160
Car: '68 corvette '73 Corvette
Engine: 427 454
Transmission: TH400
Can someone tell me which air cleaner will fit on to a holley 4160 with a hei dist.
The 14 inch cleaners i have tried hit the side of the carb. when i bought it, it had a knotch cut out to make it fit. A 9" will fit without hitting but i want something a little bigger, pref. a K&N.
The cervini 3" cowl will be going on when i paint it for extra clearance.
Transmission: 4L80E/4L80E
K&N - short for "an expensive airpath to flow lots of air & dirt into your engine". . .
If you're going with a 3" cowl hood, you can use a non-drop 14" air cleaner which won't touch anything but the air horn of the Holley.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Look for the dropped base 14x3 sets at just about any parts store... if its got the two big indentations accross from each other, on either side of the 5-1/8" carb neck, then it will work for your Holley. Every one I've seen was like that.
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
i have a 4160 and am running the edelbrock drop base, w/ a 14x3 K&N...
Did you mean the air cleaner was hitting the side of the distributor?
Car: 89 Firebird
Engine: 408
Axle/Gears: 12 bolt/4.11
I am running an hei distributor and the drop base cleaner doesnt hit my dissy but if you are having trouble with that than I agree since you have a cowl hood just put a regular air cleaner on and forget the drop. You should be able to run a 14x3 that way.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
