brass set screws
brass set screws
does any one know where you can get 6/32 brass set screws for emolsion holes with out going broke. sumit sells them for over 5 dollers each. i would like no hole or a small hole. THANK YOU!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What kind of carb is this for?
Most auto parts stores have small brass fasteners... I wouldn't worry about using a brass one though. You should be able to get a set screw in steel, in that size from a local fastener supply shop. I've got quite a few places locally that can get me them.
mcmastercarr.com would also have them.
thank you sonix it is a 850 proform carb, i bought it used and it only has plugs in the second to the bottom hole in the emulsion circuit,does any one know if that is how they come new? THANK YOU
Car: 84 Z28
Engine: 355 vortec, super victor, 13.5:1cr
Transmission: 'glide
Axle/Gears: 7.5" 10 bolt/4.56 gears
I have purchased 6, 8, &10 /32 sized set screws from a machine shop supply, but I also race radio controlled nitro buggies and they use 6,8/32 set screws so you might check towerhobbies.com, or acehardwarehobbies.com fro your fastener needs. you are really going to change your fuel curve if you fool with the emulsion circuit. Do you have a dyno, vacuum guage, and EGT?
thank you youallwatchthis i have a vacuum gauge and a wide band o2 sensor and i know what i have know dont feel or look right so i dont think i have a choice. thank you.
