Accel pump cam question
Old Jul 29, 2006 | 01:01 PM
alhiggs's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
I have minor hesitation on my new 4160 Holley on top of a Performer RPM Air Gap on top of Vortec heads on top of my new 350. Had timing issue--resolved. Read some threads about a pink cam vs. other colors. Also read about using the "2nd hole". I don't see any linkage "holes" that are adjustable
The cam is on the throttle shaft. It pushes on a flat lever that goes to the accel pump lever. Where is the "2nd hole"? Do I need clearance between the Accel pump plunger and the lever at idle?
Thanks!
Old Jul 29, 2006 | 04:31 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
If you look closely at the accelerator pump cam it has 2 or 3 different holes in it and they are numbered. You may have to remove it before you can see the numbers. You don't want any clearance between the pump plunger and the lever, you want it so as soon as you give it some throttle you get the squirt so there is no hesitation. But not too tight to where its dumping fuel all the time.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
