Problems with new Q-jet
Old Aug 7, 2006 | 01:10 PM
MKnight's Avatar
I had a carb shop build me a non-CC Q-jet. I installed it along with a performer RPM Q-jet intake. It has been running fine for 1 week but all of a sudden the other day it started idling really high and I'm watching the tach and the RPM's were really twitchy. Also it smelled rich for no good reason and lots of white smoke was coming out from the back. I really don't know what it could be.
Old Aug 7, 2006 | 03:08 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Choke heater wire come loose? Check your choke action along with fast idle cam.
Old Aug 7, 2006 | 10:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
sounds like you got an intake manifold leak
- vacuum leaks gives the high idle, coolant in intake gives the white smoke.
Old Aug 8, 2006 | 01:01 PM
Damon's Avatar
Yeah, make sure the choke wire is hooked up and supplying a full 12V. I assume it's an electrically heated choke. If not, it will not fully open and stay up on the "fast idle cam" that's part of the choke linkage. Really, any reason the choke isn't opening fully (or the linkage isn't working for whatever reason) could cause this.
A vacuum leak, maybe, but it would have to be a situation where a vacuum hose suddenly slipped off for it to be a problem that cropped up like someone flipped a light switch.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
