Holley Problem
Old Aug 11, 2006 | 08:27 PM
fastsprtcupe_82's Avatar
Car: 1982 Camaro Sport Coupe V-8
Engine: 350 Small Block
Transmission: 350 Turbo
Axle/Gears: one wheel wonder
Holley Problem
ok i have a 600 cfm Holley carb on a Weiland intake and im having problems of punching the gas at a stand still and it chugging out and popping. My dad is a mechanic and he says he dosent know what is going on with it. I think it is too much carb for the motor cause i dont know its history or what cam it has so im open to suggestions cause thats the only thing i can think of.
Old Aug 11, 2006 | 08:58 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Its not to much carb for your motor. It sounds like it is jeted to high and running rich.
Old Aug 11, 2006 | 09:01 PM
we have tryed that too, but if we lean it out it runs worse at high rpms, sorry forgot to put that in the question, and we also checked the accelerator pump and its fine
Old Aug 11, 2006 | 09:42 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
wrong pump shot size probably. change squirters, or perhaps it needs more stall, more gear, etc etc. What's the timing set? floats? fuel pressure? check any of that?
Old Aug 11, 2006 | 09:48 PM
92comaro/conver's Avatar
Car: 92 comaro-rs
Engine: 3.1liter/supercharged350 comingsoon
Transmission: 700R4 trans.
have you checked your syntriffical advancded on dist.does car do allright when taken off normal/if it does check dist.your advanced might not be opening fast enough
Old Aug 11, 2006 | 09:52 PM
i have checked all of that i forgot the setting i will get that on soon but i remember that it was all fine, but i havent checked gears in the rearend yet and i have to change them out cause going 55 the rpms rev high so im gonna put a more streetable rearend and put a 700r4 overdrive in it cause i have a 350 3 speed in now in it but idk, and the distributor is set even and regular take off is fine but as soon as you put it to the floor it chugges and popps gas out of the carb like a backfire
Old Aug 11, 2006 | 10:01 PM
Car: 92 comaro-rs
gears should not have anything to do with backfiring are bogging down is it a rebuild motor gears sound like they are steap
Old Aug 11, 2006 | 10:04 PM
xpndbl3's Avatar
Car: 1984 Z28
9 times out of 10 a carb problem is really an ignition problem. a 600 cfm holley would be a vacuum secondary, so did you try changing out the secondary springs at all?
All i know is the guy that had it before me took the v-6 out and put a rebiult motor in it but i dont know what he did to the motor
Old Aug 11, 2006 | 10:05 PM
he said it had a mild cam
Old Aug 11, 2006 | 10:07 PM
I have messed with the springs and it didnt help and i have checked all vacum lines and fittings and there arent any holes in them
Old Aug 11, 2006 | 10:10 PM
sorry my computer is being dumb and says that it isnt sending the respond and it actually is and reset my respond
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
355tpipickup
Aug 19, 2015 10:02 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
