Which Fuel Pressure Regulator
Old Aug 23, 2006 | 02:07 PM
zrated57's Avatar
Right now my car has TPI set-up, but I'm putting a carbureated 383 in it. I want to keep my stock fuel pump and just get a fuel pressure regulator to keep the pressure low enough for a carbed engine, instead of fuel injection. What I need to know is which FPR i need to buy that will also work with the return line back to the tank. anyone know a specific one i should use. like part numbers? thanks a ton
-erik
Old Aug 23, 2006 | 03:25 PM
jimpfaffy's Avatar
Car: 1989 camaro rs
Engine: gmpp 350 ho
Axle/Gears: posi w/3.73
fpr
i run a mallory 4309 3 port regulator it is adj. from approx. 3-12 psi. cost around 75.00. works great with walbro elec. pump in tank.
Old Aug 23, 2006 | 03:39 PM
zrated57's Avatar
will it work okay with my stock fuel pump? thanks
Old Aug 24, 2006 | 07:03 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I run a Mallory 4 port on my camaro, and I am still using my stock fuel pump. Been using this setup for about 6 years now.
Old Aug 24, 2006 | 09:16 AM
zrated57's Avatar
cool. what is the part number for the mallory 4 port and what are the other ports used for?
Old Aug 24, 2006 | 11:21 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
mallory #4309 and it's the 3 port regulator, which actually has 4 ports on it since one of those ports is the send line.
Old Aug 24, 2006 | 02:11 PM
zrated57's Avatar
awesome. i ordered the 3 port 4309 mallory port from jegs. i would have purchased one on ebay, but it was cheaper to buy it from jegs. HAHA. thanks everyone
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
