What kind of gains??
Old Sep 8, 2006 | 07:35 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
could i get from goin from TBI to a carb???...probably worse gas milage, but what are the advantage's and whats the going rate for it?? thanks
Old Sep 8, 2006 | 08:37 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
nothing. You will see maybe gain something and maybe loose something. Either way, a well tunned carb can run with EFI. The drop only 1 or maybe 2 MPG down. The problem is that no one ever gets them tunned totally right.
If you are looking HP, look somewhere else. If you are looking to fix/get rid of TBI, then get a carb and don't worry about MPG.
If your engine doesn't need any more fuel then no fuel delivery system, even the best in the wold will not make more HP.
Later
-Dennis
Old Sep 8, 2006 | 09:04 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have a carb in my sig for sale if you are interested!!
Depending on what you have done to your car, you can pic up more performance else were. Exhaust & Gears are always the best place to start for performance. A engine is just a air pump. The more air you can get in and the quicker you can get it out the faster it will run.
Old Sep 8, 2006 | 09:49 AM
Engine: LS3
I too have a carb for sale. A polished Holly 600 CFM vacume secondaries. $100.
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
hartsmike
Oct 2, 2015 07:11 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
