CHOKE LIGHT FLICKERING & RELAY BUZZING!!
Old Sep 14, 2006 | 02:44 PM
FJA's Avatar
FJA
Car: 1986 & 87 Camaro
Transmission: 700R4 & PG
Axle/Gears: 28spline 4.10 & KTRE 12 bolt
I have a 86 LG4 Camaro with a CC Q Jet. The choke light intermitantly flickers. Also the choke relay intermitantly buzzes. Any sugestions? Seems to act up when idleing in gear. I checked the choke connections and replaced the relay and still the same problem.
Thanks Frank
Old Sep 14, 2006 | 03:03 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
On my '84 the choke light is also an indicator when there is an electrical problem. Check for a loose wire or a possible intermittent short or a loose ground.
Old Sep 14, 2006 | 03:22 PM
That light might say "Choke"; but it's REALLY the "Alternator" light. It just happens that when the alt goes bad, the choke also doesn't work, which is an emissions failure, which the feds evidently required them to provide the warning light for.
The particular part inside the alternator that's making it do that is probably the diode trio. But, if that's gone bad, then odds are, the rest of the alt is in not so good shape either.
Replace your alternator.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
GTAman
Mar 15, 2019 11:40 AM
1992CamaroGirl
Dec 25, 2017 08:45 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Omega
Aug 10, 2015 12:46 PM
