Missing Vacuum line
Old Sep 20, 2006 | 01:16 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Missing Vacuum line
Ok guys,
I just swapped carbs (stock Q-jet) in my 305 powered 84 T/A. I went with a new Q-Jet from Jet performance products. I have no problems with the carb, but man, I was hooking up the vacuum lines that I removed from my old carb, I counted 6, and now I'm missing one...
Facing the motor, it's on the right side of the carb just below the three pronged power connector. I checked GM's vacuum line diagram and it appears to be the line that comes from the distributer however, I can't find any lines that come from the distributer. I have re-hooked up everything that I had taken off, triple checked it and I can't find this missing line. I even checked the other ports on the new carb to make sure I didn't hook it up to one of those and I haven't. I've pulled the damn thing apart three times completely, and re-hooked it up and I'm still missing this line. How and the heck does a vacuum line just up and walk away?
Old Sep 20, 2006 | 01:29 PM
Madcrazy's Avatar
Car: '91 Formula
Engine: 5.0 TBI
Is it runnin fine without? if so I would just leave it. Also, could you have possible removed it when u took the old setup off? maybe it's on the old carb.
Old Sep 20, 2006 | 02:20 PM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
Check your air cleaner - there's a vac hose that operates the thermac valve. It may have pulled off when you took the air cleaner off.
Old Sep 20, 2006 | 06:22 PM
Ozz1967's Avatar
Car: 1984 Trans Am
OH MY GOD!! Your a genius! I completely forgot about that one! I'll move one hose that I now know I've put in the wrong place and poof...it all makes sense! LOL Thanks!
Todd84Z
Sep 4, 2015 08:02 AM
Jote4805
Aug 25, 2015 06:11 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
