need general wiring help for starting/running system for carb
Old Sep 29, 2006 | 10:58 AM
HuggerI-ROC's Avatar
Car: 99 Mystic Green Trans am
Engine: LS1: Heads, MS4 cam, bolt'ons
Transmission: Fully built T-56 w/Spec3 & Pro 5.0
please help me out if you got some time
https://www.thirdgen.org/forums/elec...ml#post3075756
Thanks, JR
Old Sep 29, 2006 | 01:06 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
like that pic you attached, its great and simple. hope it stays arround for future use.
1. i never used choke relay or rarely even a choke. im in s. florida.
2.i dont use a fuse for alt but yes on coil, you need to find out there amp draw. ex: (80A alternator) then go 125%. 80 x 1.25 = 100A
3. run ground cable to motor, also run strap from firewall to motor. on older chevys either stud off exhaust manifold or alt mount bracket.
4. 10awg is fine as long as your alt isnt a monster and try to find wire with high temp jacket when going down to the starter.
hope this helps
Old Sep 29, 2006 | 11:26 PM
Thanks, for your help all keep those things in mind.
I'm going to wire it tonight so all let you all know how it turns out.
Thanks, JR
Old Sep 30, 2006 | 06:05 PM
Everything went great and without a hitch
I got it and started her up on the first try.
Thanks for your input and wish me luck on the rest on the nightmare
i.e. headlights, flashers, taillights o well off I go.
All post a picture and update my little drawing,
with what I change, once its all cleaned up.
Cheers, JR
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
tero
Aug 15, 2015 02:47 PM
