which metering block will work
Old Oct 8, 2006 | 07:21 PM
Iroc Adio's Avatar
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
i have a holley 650 DP with a Proform Main body. My primary metering block has a striped out idle mixture screw. Could i use a metering block from a 750 DP? Or could i buy a kit from proform or quickfuel? thanks a lot!
Old Oct 9, 2006 | 03:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I can see the reason for the confusion. But, the 750 DP metering block should work.
You could buy a new block from one of those sources if you like.
Old Oct 17, 2006 | 10:32 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
one of the advantages of the proform or quickfuel metering blocks is the changeable idle feed restrictions, another is the fact that they are billet pieces and won't warp. there are two versions available, one for racing and one for street.
disadvantages,,,, sixty one bucks!
i'll let you know what i think of the race version when the 383 is finally running (hopefully very soon!). they are very nice pieces and proform and quickfuel both have EXCELLENT customer service!
Eric B
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
lakeffect2
Aug 23, 2015 08:44 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
