Throttle Cable Length?
Old Oct 16, 2006 | 12:35 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
Transmission: Super T-10
What is the throttle cable length needed for a V-8 carbed engine.
The reason I'm asking, is that, I used to have a TBI and now have a carbed system. My cable is frayed and I want to replace it. I was looking and found that they make a 30" cable and a 44 1/2" cable. The 44 1/2" cable seems like it would be too long. Is the 30" the correct length?
Thanks!
Old Oct 16, 2006 | 02:58 PM
Damon's Avatar
Not sure, but you could also look it up by application. Just look for a cable for an 85 Camaro with the 305 V8 and 4bbl carb.
When I converted by 92 TBI Camaro over to carb the stock throttle cable was also a bit long for use with the 4bbl (depending on which bracket you use- I made mine fit) but I don't think it was anything like 14" longer than a stock 4bbl cable.
I bet the 44" unit is for a TPI engine with the TB way at the front of the motor.
Old Oct 16, 2006 | 04:27 PM
snowman_az's Avatar
Car: 1982 Z28
Engine: 355 V-8
Damon,
Thanks! I just ordered a 30" cable.
The 44" cable looks like a snake on steroids, under my hood.
Thanks again!
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
