FUEL REGULATOR (3-WAY)
Old Dec 31, 2006 | 04:07 PM
estone06's Avatar
Car: 1991 Camaro RS
Engine: 350 stroker .40 over 11:1 comp
i have a Holley 600cfm on top a 383. i know, i know.....
anyway there is also a mallory 3 way regulator in line, all connections are correct hoses and fittings as well as the sizes. My problem is that I have 12lbs running through my fuel lines to the carb and it is causing the carb to spit gas out from the needle. basically it is flooding itself out.I have tried to adjust the regulator but 12 is the lowest reading i can seem to get. I take the nut off as well as the spring and screw. turn the pump on, i see the needle going everywhere after 15lbs. So i turn the screw as much as i can, it stops before my fuel pressure can go below 12 lbs.
-----Does anyone know how to adjust the regulator....Am I doing it wrong?????
Help, Help, Help!!!
Old Dec 31, 2006 | 06:26 PM
estone06's Avatar
Car: 1991 Camaro RS
Problem solved, was doing it correctly after all, just had to go a bit further.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
