WTT: TPI for Carb Setup.
Old Jan 5, 2007 | 11:34 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Hello Everyone.
I am willing to trade my whole entire TPI setup for a carbed setup.
Plenum
Runners
48mm TB with formula aluminum plate
Base manifold (intake holes have been modified to fit vortec/ center bolt heads) Will work with any kind though.
aluminum distributor cover
fuel rail
airfoil
all air ducts (all 3 pieces includes K&N filter)
19lb injectors
hard fuel lines
knock sensor
ESC module
MAF sensor
MAF Relays
TPS sensor
IAC sensor
MSD remote coil
TPI distributor w/ accel cap
EGR valve
Various temp sensors
Engine harness
TV and Throttle brackets
Here is what I want....
750 double pumper 4bbl
Aftermarket Intake manfold (performer rpm or better)
HEI distributor
Chrome or aluminum air cleaner 14"
(all associated brackets for throttle, and TV cable.)
3port AFPR
engine harness unless I get to keep mine.
Best offer wins it, if your setup does not have something on my list then include the difference in order to purchase it, my car is a daily driver and I need all the parts. My parts are top notch and I will make sure the conversion is complete. Serious inquiries only.
Old Jan 20, 2007 | 06:01 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
bump
Old Jan 23, 2007 | 03:26 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
I have a GM HEI dist. with vaccum advance and MSD coil for 75 shipped. I have a 14 x2 K&N air filter as well that will be 20 shipped. or 90 for both shipped.
Old Jan 23, 2007 | 06:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not sure why you're posting here. Most people on the Carb forum aren't looking for TPI. Plus, it's a violation of Board rules.
I'll give this one more day, then it's lights-out. Post on the Classifieds forum.
Old Jan 23, 2007 | 08:42 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Eh, If no one chimed in by now it probably wasn't going to happen. You can kill it whenever you'd like.
pimp2303
Jul 27, 2017 02:03 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
