Main body without air horn or K&N Stubstack?
Old Jan 23, 2007 | 04:44 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
Just like it says. I want to get some opinions. I wouldn't mind keeping the choke but, but if the power gains are substantially more using the main body without the air horn, than using a carb with a stubstack then I would rather go with that. Any ideas?
Old Jan 23, 2007 | 05:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
proform mainbody is usually worth 15hp or so over an otherwise restricted carb. If the motor is already overcarbed then it might not matter.
Old Jan 23, 2007 | 07:54 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
Anyone who knows anything more about the K&N stubstacks? They claim 10% increase in hp because it smooths the airflow out into the carb. I can't imagine a carb with a choke and a stubstack being as good as as a proform main body.
Old Jan 23, 2007 | 08:09 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Its not... it might help smooth things out for carbs with a big choke horn, like a 4150/4160 Holley, but something without one, like a Proform body or Holley HP body, won't make any use of it.
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
mdtoren
Aug 23, 2015 12:52 PM
PestilenceIV
Aug 20, 2015 02:33 AM
86White_T/A305
Aug 17, 2015 12:16 AM
