Edelbrock Elec. Choke: Hookup in fuse panel?
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Hey guys, wiring up the edelbrock choke on the 1411 performer. Video says to insert the positive lead into the fuse panel where the "pow acc" fuse should go, however, there is already a big metal fuse occupying that spot. Where did you guys hook up your choke to?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
use the factory choke hot wire
make a ground wire for the other side of the choke circuit, if the choke is a two wire one
Transmission: 4L80E/4L80E
I may be making the king of all assumptions, but a '90 Camaro TPI wouldn't have a choke wire.
The "big metal fuse" is a circuit breaker.
I'm not familiar enough with the layout of that fuse panel to provide specifics, but there should be other unused ignition-switched slots open. If not, tap off a switched line on the switch side of the fuse/circuit breaker, such as that "pow acc" slot, and use an in-line fuse pigtail (available from most parts stores).
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
I did that except i taped into the wiper fuse havent started the car yet still working on the swap hope it works.
So you can safely just plug the choke into the panel along with an existing fuse? As if they were 'sharing' the same slot?
The choke is very low draw. Shouldn't be a problem.
The advantage of doing it the way I described is you wouldn't add load to the existing fused side of the circuit. The supply side won't notice the extra load.
How do I tell which side is the supply side?
Take the fuse/circuit breaker out. Turn the ignition to "on", put a voltmeter or light on each side of the fuse. The one with voltage is the supply side.
Sweet, thanks five7, always a big help!
Hotrodboba400
Dec 10, 2019 07:07 PM
sreZ28
Oct 22, 2015 08:21 AM
gta892000
Sep 16, 2015 12:37 AM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
