engine backfiring after..
Old Jan 31, 2007 | 02:56 PM
1987camarosport's Avatar
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
Hey all i have a question, I used sea foam in my camaros motor. its a 350 with edlebrock intake and carb headers anmd 3 inch echaust and performance ignition. non computer controlled. I just used sea foam through my carb and went for a drive no smoke really since the motor has 30k on it. my problem was when i held the gas at about 2500-3000 and stomp on it to the shift lite about 4500 there as loud BANGS! and small flames somin outa the exhaust. and a wee bit of black smoke but it dosent seem to do it now. what can it be? and if no bange from the exchaust tips it could be herd in the headers and piping under the car.
Old Jan 31, 2007 | 03:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pull the plugs and clean/replace them. If they're clean, you either have a weak ignition issue, or you got a piece of loosened crude inbetween an exhaust valve & seat (or multiples).
Old Jan 31, 2007 | 03:32 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
Ok thanks. I never had that problem till the sea foam went in. it dosent do it now it did it about 6 times or so. but it seems to be running fine now..
ok just checked a plug its black and its carbon fouled.. .
Old Jan 31, 2007 | 06:39 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
which plugs should i get tomorrow. i have a accel hei ignitin accel wires a 350 with cam. heads. etc etc.. im assuming ac delco but i always use NGK on my focus.
Old Jan 31, 2007 | 11:48 PM
five7kid's Avatar
Most any copper core plug will be fine.
Old Feb 12, 2007 | 12:57 PM
ino's Avatar
ino
Car: 87 firebird
One time my car back fired was because one of my spark plud wires had a hole in it. It was to close to manifold and was arcking on it.
Andrew6.688
Dec 13, 2015 10:59 AM
Reddeath210
Oct 6, 2015 08:20 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
