is this enough pump
Car: 1984 z28 camaro / 2019 accord sport
is this enough pump
http://store.summitracing.com/partde...2D1792&FROM=MG
is this enough pump for my motor and possibly 150 shot of n2o, 200 at the most.
what fittings should i get i want to go 1/2 hard from tank to pump
1/2 hard from the pump all the way to the front
1/2 to 8 an adapter then this filter
http://store.summitracing.com/partde...650103&FROM=MG
8 an braid to this regulator
http://store.summitracing.com/partde...D4307M&FROM=MG
6an to carb
6an to carb
Car: Camaro IROC-Z 1987
Engine: 454 BIG BLOCK
Transmission: TH700R4
Axle/Gears: 3.42 gears Posi trac
ím sure is enough pump 160 gph is a lot of gas, im running a modified 454 and have no after market pump on it and it runs very strong but definately i need one
or would it be worth the extra money to get this pump
http://store.summitracing.com/partde...5&autoview=sku
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Why not a normal block pump? Since you're running carbed?
Oh, I guess you need the high pressure for the nitrous? Do you really?
I don't think you need that much flow, I think the first one would be lots of fuel.
i have heard some ware that you always want to over kill the fuel system because you never know what you will want to do next.
right now i would be happy with a 12 flat but who knows how long that will last, and i onlly want to do the fuel system once.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
