Junked the TPI, installed a carb....
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
After starting my cam swap LAST april I finally got it done and on the dyno again. the blue lines are the stock TPI setup with 21 year old valvetrain. The red lines are the results of a performer intake, 600 cfm Edlebrock, Summit TPI cam set( had planned on staying TPI) fresh heads, timing gear set, push rods, 1.52 roller tip rockers, etc. after I did the headers, y-pipe and catback it had only gained 7hp/3tq. My jaw about hit the floor when i saw the numbers
Got to get a balancer cover since the balancer has slipped a bit and take some fuel out since its rich and it might see 190hp!!
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
so the blue is with the cam and headers too or did you install the full exhaust and a cam then put a carb on it and dyno it?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
switch to a performer RPM to pick up another 15 hp easily and swap to a holley double pumper for more performance as well.
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
The red was after all mods
No doubt. Ive only got $50 in the carb and intake so im not complaining!
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Hey alex, (its Juiced91z from CCFB) did you gut all the excess wiring from the car? when i get back from kuwait think you could give me a little guidence on what wires i can take out, i dont really want to rip it all out and re-run all new wire for things that i need. i would appreciate it a bunch, thanks
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
just don't chop off the alternator harness; i knew someone that did that...
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Thats a piece of cake, we cam get that done.
Tobias 05, sent ya a pm back on the other site.
Car: 91 z28
what is that about a 20% loss of HP from the crank to the wheels? 215 at the crank isn't too bad for now alex, hoping for about 275 at the wheels myself.
man, why didn't you ask me? Its simple!
...you need that pink wire, that white one, that green one, 3 red ones...
toronto formula
Nov 10, 2015 06:17 AM
Sanjay
Aug 12, 2015 03:41 PM
