back barrels wont open at wot
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
i have a holley 750 with vacuum secondary but the back barrels will not open at wot and i have a yellow spring in it to. any ideas why this would happen?
Transmission: 4L80E/4L80E
A couple of possibilities:
1) The vacuum signal passage is plugged somehow or another.
2) You're blipping the throttle in the driveway and expecting the secondaries to open while you watch.
Yeah they dont open when your in park.. without a load on the engine.. I realized that, after revving the **** out of mine for 10 minutes =P..lol
no at dragstrip then a i used a paper clip on the rod on the diaphran its not opening it just start 2 days ago
mdtoren
Aug 16, 2015 05:45 PM
