Fuel Pressure
Fuel Pressure
Well its getting warmer enough to go outside and not get frostbite after like 5 mins so i decided to start fixing the cars little quirks. Well i knrew the car was running way too rich because even half throttle would cause it to bog down. Well when i bought the car it had a fuel pressure gauge hooked up right before the carb well its a little damaged but still works and says the cars running at 12 at idle. So my question is do i need to drop the tank or is there an inline pump that i have to take off. thanx in advance
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
You just need a fuel pressure regulator. Drop that pressure down to like 4-5psi for the carb. You don't wanna run to much pressure or you can damage your carb!
Transmission: 4L80E/4L80E
You won't damage the carb until the overflowing gas catches on fire.
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
