carb issues
Old Mar 8, 2007 | 08:18 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
carb issues
After i completed my carb swap i cant keep the car running for more then 5 mins at first the regulator leaked fixed that now i cant set the float. with the needle and sean fully screwed clockwise i still get flooded with fuel i kno its suppose to drip out the sight hole mine floods the fuel pressure its at 6.25 psi
Old Mar 8, 2007 | 08:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Some crud got in the needle & seat, or they're damaged.
Do you have the filters behind the inlet nuts on the carb?
Although now that I think about it, screwing the nut clockwise would raise the float. Perhaps you should turn it the other way.
Old Mar 8, 2007 | 08:24 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
yes i do have filters the carb is brand new out the box is 6.25 to much pressure i thought clockwises lowers float?
Old Mar 8, 2007 | 10:26 PM
five7kid's Avatar
To be honest with you, the few times I've had to adjust mine, I just turn it the direction that does the right thing.
Old Mar 9, 2007 | 06:26 AM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
looks like ill try counter clockwise then can have the float levels that high hurt the carb?
Old Mar 9, 2007 | 09:27 AM
five7kid's Avatar
No.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
