q-jet differences?
Old Mar 8, 2007 | 11:40 AM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
q-jet differences?
My Z28 is an 83 but my carb accroding to the casting number is from a 87. Any differences i should be aware of?
Old Mar 8, 2007 | 12:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Nope. Assuming both are cc-qjets there shouldn't be any difference.
Old Mar 8, 2007 | 02:48 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
there are differences but none to worry you,
jetting, is one difference,
some CCC q jets had an extra electric internal control device inside them, depending on the application, was an extra one wire device in them, one example was on the 86 c-10 305 pickups
good luck
Old Mar 8, 2007 | 03:46 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
well only connectors on it are for the tps,mc solenoid and choke. If the jetting is different what should i jet and rod it to currently have an lg4 but would like to re-use the setup for a 350 in the future.thanks
Old Mar 8, 2007 | 03:56 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The primaries should be fine on a 350. You'll want to change your secondary rods/hangers if you've got the stock LG4 ones on there. There were some vaccuum port differences for later q-jets, but no show stoppers.
What secondary rods/hangers are in it now?
Old Mar 8, 2007 | 04:00 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
I believe they are CK rods
Old Mar 8, 2007 | 04:08 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
or maybe ch cant really read it clearly
Old Mar 9, 2007 | 06:30 AM
naf's Avatar
naf
Looks like standard lg4 rods. You'll want to upgrade your secondary rods/hangers. There's a tech article on this site that includes a recommendation. I can't remember which ones I put on my camaro, but I'll check tonight.
Old Mar 9, 2007 | 07:05 AM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
yeah i"ve seen the article i think it mentions cc rods sound ok for my 305 then should i change again for a 350
Old Mar 9, 2007 | 11:10 AM
Sonix's Avatar
Car: 1982 Trans-Am
Yea CH rods are basic LG4 rods.
Try to find some DR rods, or DA rods. DR's came on L69's, and a bunch of other GM vehicles.
Edelbrock has some aftermarket ones, but their weird letters, ones that i've never seen in the JY. Look 'em up on the chart to see if they'd be better than what you already have, and would be worth buying. Otherwise, go JY diving!
69GTOby
Apr 18, 2016 02:34 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
