TPI TO DUAL QUAD
Old Feb 22, 2007 | 08:51 PM
NORTHSLIDER's Avatar
Car: 79, 85, 87,91 TRANS AM'S
Engine: 455,305TPI,350TPI,350TPI
Transmission: MUNCIE, T-5, 700R4'S
Axle/Gears: YEP
TPI TO DUAL QUAD
IM REMOVING MY STOCK 350 TPI SETUP AND THINKING OF GOING TO A EDELBROCK DUAL QUAD SETUP. THEY GOT THEM FROM SUMMIT WHICH COMES WITH:
INTAKE
2 500CFM CARBS
AIR CLEANER AND BASE
ALL GASKETS
ALL LINKAGE AND
DUAL FEED FUEL LINE
I JUST DONT WANT TO DEAL WITH THE TPI THE CAR IS AN 87 GTA AND THE 5.0L BLEW(BEFORE I BOUGHT CAR) THE GUY BEFORE ME BOUGHT A 350 TPI OUT OF AN 89 IROC-Z AND HAD IT BOLTED IN BUT NOT WIRED UP. NOW ITS MY T/A. I DONT KNOW IF I'M GOING TO CARB IT OR JUST SELL IT AND MOVE ON THE SOMTHING ELSE. IF I DO CARB IT IM THINKING OF GOING WITH THIS COMBO
Old Feb 22, 2007 | 09:00 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What are your intentions? Dual carbs are for appearance, not performance.
Old Feb 22, 2007 | 09:02 PM
Axle/Gears: YEP
IM LOOKING FOR LOKS AND A GREAT SOUNDING EXHAUST TOO
Old Feb 22, 2007 | 09:03 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
First off... STOP YELLING!!!! TALKING IN CAPS MEANS YOU ARE YELLING AND ITS REALLY ANNOYING TO LOOK AT TOO!!!
Now, on to your question. Don't do with a dual carb setup unless you are strictly doing this for looks. You will go faster with a single 4bbl carb and high-performance intake. Its been proven thousands of times, again and again. Also, if you don't have alot of carb tuning experience to begin with, trying to setup two carbs properly is a total nightmare. I once heard someone say:
"It only takes one bad day to make the sanest man alive go totally bonkers"
And I can't think of a better way to explain what its like trying to tune a pair of 4bbl carbs, especially on such a small engine, when you have little to no carb tuning experience.
IMO, the ticket for you would be to get an Edelbrock RPM or Weiand Stealth (8150 PN) and get a 4150/4160 style Holley, 650-750 cfm. Thats about the best street/strip setup out there for a mild 350 IMO.
Old Feb 22, 2007 | 09:08 PM
Axle/Gears: YEP
whats a good cam to go with if i go with a stealth intake and a demon carb. these motors are roller from the factory right?
Old Feb 22, 2007 | 09:30 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
IF its truly an 89 block it will be roller
Old Feb 23, 2007 | 10:40 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
There are better ways to go about this than just jumping into a dual quad setup. But, to each his own. Have fun tuning
Old Feb 23, 2007 | 11:14 PM
Axle/Gears: YEP
IM JUST GOING TO SELL THE CAR AND PUT A FRESH PAYMENT ON MY MORGAGE
Old Feb 24, 2007 | 09:41 PM
Rick King's Avatar
Car: 1987 TA
Engine: 350 stock/twecked
WTF mabe, but not in all out performance --tunnel ram for example or sheet metal intakes!!!!!!!!!!!
Yeea you are right as most applications they are for looks and single with todays intakes will outperform a dual,, but who can argue with the looks of the old 302 intakes from elderbrock Cross ram
later and
GB
rkl
Old Mar 6, 2007 | 07:18 PM
86FireBird305's Avatar
Car: 1986 Firebird LG4
Engine: 305 5.0 LG4
Transmission: TH-700R4
now im still kind of iggnorant when it comes to this...but im workin on it...
what is that statement based on cuz ive never head that before i would imagine more carbs=equal more fuel flow=better base for power...im not trying to dispute u but im just looking for an explanation if possible thanks
Old Mar 6, 2007 | 10:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Back before there was an aftermarket, the only way to get more flow than a small OEM carb was to use two small OEM carbs. Now that there is an aftermarket which offers things like 4500 series carbs that flow up to 1400 CFM, there's not much need to deal with the tuning problems of dual carbs.
Old Mar 7, 2007 | 02:39 AM
pmpnavt's Avatar
Engine: L98 350
Transmission: 700r-4
tunnel rams looks great
They also run great too....as long as you dont keep messing with them like i do thats where the whole "it only takes one bad day..." thing comes into play
Old Mar 7, 2007 | 04:20 PM
Axle/Gears: YEP
NICE!!
Old Mar 7, 2007 | 10:34 PM
pmpnavt's Avatar
Engine: L98 350
one thing though as much as i hate to admit it, a single carb would be much easier to tune. but the way the car looks, its just not an option anymore
if your just going for the low rise dual carb, you would be better with a single. when i do things i tend to go a bit over board, but thats why i drive a toyota to work :P
Old Mar 10, 2007 | 01:13 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Or 1,000 times better yet...A "long-ram" 413
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
Jlanz55
Aug 17, 2015 07:15 AM
Sanjay
Aug 12, 2015 03:41 PM
