Broken carb!!!!!!!
Old Mar 8, 2007 | 09:44 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Broken carb!!!!!!!
I searched for this and couldn't really get a good settling answer!
I let a buddy use one of my Edelbrock Performer Series #1406 and he hooked it straight up to his stock fuel system for a 2.8L multi-port fuel injection Well then I tried to use it after I got it back and my car wouldn't stay running. So I pulled it off and rebuilt it and it was still doing the same thing So I just threw another one on that I had and put that one on the bench. I do have the Mallory 3-port regualtor running 5psi, so I know it's not a pressure issue any longer. Could the fuel pressure from the 2.8L have ruined like the plunger or something? (cause that didn't come with the rebuild kit, so I didn't replace it)
Any information is appreciated!
Old Mar 8, 2007 | 09:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Did you check the float height and drop when you rebuilt it?
Old Mar 9, 2007 | 09:24 AM
RITTER's Avatar
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Yes I set both of them to what the rebuild instructions suggested. When I pulled the carb apart to rebuild it, there was a lot of this clear jelly looking crap in both fuel bowls, not sure what it was so i just cleaned all the tarnishing and all that junk out of there. Replaced everything the kit came with! And it was still a no go!
Old Mar 10, 2007 | 02:09 PM
RITTER's Avatar
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
So nobody knows what could be wrong with my carb?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
skeltor
Feb 2, 2016 10:37 AM
customblackbird
Oct 1, 2015 04:30 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
