Adjusting throttle cable?
Old Mar 11, 2007 | 11:22 PM
devildust's Avatar
I tried doing a search and found some old threads but the site that were on there did not work anymore? I have a holley carb on a 350. My problem is that I dont think it opens all the way the the pedal is down, and it doesnt down shift when I floor it, I already tried adjusting the TV cable. I there a way to check if the throttle cable is not tight enough? Thanks
Old Mar 11, 2007 | 11:28 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
have someone mash the pedal while your under the hood to see if it opens the throttle all the way. If it does, good. If not, you have some work coming to ya!
Old Mar 12, 2007 | 08:12 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Are you reusing the stock bracket's for the throttle and tv cable ?
Old Mar 12, 2007 | 12:25 PM
devildust's Avatar
I dont know, I dont think its the stock bracket. I can put some pics up, if that would help.
Old Mar 12, 2007 | 12:34 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I had the stock bracket on my car and I have a 355 with a 650 mighty demon. And the geometry was out of wack so I just bought this to correct everything.
http://www.csr-performance.com/Merch...gory_Code=CT41
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
