shifting at high rpms
Old Mar 16, 2007 | 09:40 PM
vanman84's Avatar
Car: 1984 chevy camaro berlinetta
Engine: 305 5.0
Axle/Gears: stock
my car is shifting from 1 to 2 at like 4000 rpms and i drive at 30mph at 3000rpms its a 305 5.0. i just had a new intake put on.could it be the throttle valve cable? if so how do i adjust?
Old Mar 17, 2007 | 12:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Where the cable housing mounts in the bracket by the carb, there is a release button (looks more like a plate). Press that in and pull back on the cable housing. Release the button and let go of the cable. Slowly depress the accelerator pedal to the floor, and it will click the TV housing until it is properly adjusted. You can also just open the throttle from under the hood.
Old Mar 17, 2007 | 01:47 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
yep adjust your TV cable......
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
someone972
Aug 30, 2015 12:52 AM
dhonda200
Aug 11, 2015 11:50 PM
