I gots a problem..
Old Mar 22, 2007 | 08:50 PM
1987camarosport's Avatar
Car: Camaro
Engine: worked 350
Transmission: automatic
Axle/Gears: 3:73
I gots a problem..
hey all. i have a problem with my camaro. Its got a 350 with goodies headers etc.. my problem is.. car wont start when hot... i put the heat shield stuff around my starter still exists(still cranks slow).. i have a fuel filter with a sight glass when i shut the motor off (just ran till hot) there is no fuel in there once shut off and it wont start.. but when cold, pump twice and there is fuel in there..
IT starts up after about 30 minutes or so of cooling... and when it does flames fly outa the carb if i tryed startin it before would a carb shield help?: PS i have a fuel pump mounted to the block im assuming its stock... what type of gasket spacer do i need to space the fuel pump from the block a part number is great..
OK im going to try the remote Starter Solenoid mod tomorrow and ill report on how it goes..
Old Mar 24, 2007 | 11:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: I gots a problem..
So when it's hot, is the problem that the starter cranks it too slowly, or does it crank nice and fast, but there's no fuel in the bowl?
It'd either be your starter is getting too hot, or you're getting a vapor lock sorta thing. Usually vapor lock would cause the car to stall out when running though, not just a no start issue.
Are you running a mech pump on the block only? No electric pump in the tank anymore? (it's been removed by you?) Is this a return style pump? Exhaust is a decent distance away from fuel lines, specifically near the passenger side header collector?
What's the starter like? Old stock one, new factory one, aftermarket etc? Usually this is what happens when the starter just starts getting old. Try a new mini starter, like the ones for LT1 cars. Assuming your battery is good, wiring from starter to battery is good, this should spin your motor over good and fast.
I wouldn't bother trying to space the fuel pump from the block, that's not the problem.
I'm not sure what to make of this. Timing is right? Make sure it's not super advanced.
Old Mar 24, 2007 | 02:40 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
ok well it turns over very slowly... im in the process of trying a remote solonoid but when ever i connect the battery the starter engages...
Old Mar 24, 2007 | 02:47 PM
Sonix's Avatar
Car: 1982 Trans-Am
ah, you're just wiring it up wrong. You'll figure it out. I've never used one so...
I think your starter is just on it's last legs. When the engine is nice and cold everything is easy so it'll crank it over ok. A new starter, like a ministarter would work great. The remote solenoid might help for a bit, more like a bandaid though.
look up some threads about this in the past, sofakingdom has posted a few thoughts about our "stone age" technology starters vs the new style ones. I don't know enough about the inner workings to comment (my stock 305 one works great for my hot 350), but the new style ones are much better apparently.
Old Mar 24, 2007 | 02:51 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
yeah ive read those i just wanna get by for the mean time.. my old solenoid only had 2 wire hook up... and the new one has 3 i replaced the terminal with all the wires onto the new one.. and the termilal with the 1 wire on the new one.. jump[ed out the old one and the satarter just stays on wether or not the key it turned??
would it work ok if i just wired it battery to new solonoid.. wiloid to old one.. and leave the other wires intack>>
Old Mar 24, 2007 | 07:13 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
ok well i got the remote solinoid in and it still does the same thing im thinkin maybe time for a new starter...
Old Mar 25, 2007 | 11:15 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
i had the prob with my camaro before the motor swap. i went through 3 starters. truns out my block was getting too hot. I went to a mini starter and i don't have any more probs.
Old Mar 25, 2007 | 06:03 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
i think im gunna get a 92-96 vette starter since people say they fix the heat soak issue.. where in CT are you 89 ho rs?
Old Mar 25, 2007 | 06:30 PM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
I got a CVR gear reduced one it is damn good and fast, my tach reads 400rpm when the car is cranking with no fuel.
My old one was screwed it would engage but the gear would just slip on the shaft and it went real slow when it was working (didn't read on the tach).
Old Mar 25, 2007 | 06:45 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
do you have any heat soak problems with that one?>
Old Mar 25, 2007 | 08:13 PM
VenomX-87's Avatar
havent so far, when the car use to overheat to 260'F i would shut it down and it will still throw it over without a problem.
EDIT: i needed to add the flywheel cover has to be cut abit to fit the mounting point for this starter because it has the holes to mount to all Big blocks and small blocks. (they use them in drag cars over here) so it has no problem cranking over a small block
Old Mar 25, 2007 | 08:27 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
with the tilton i have not had any probs with heat soak and also if you have a slightly dead battery it will still start. I am about 10 mins from the casino. In Griswold.
Old Mar 25, 2007 | 08:46 PM
Car: Camaro
Engine: worked 350
Axle/Gears: 3:73
tilton? do you have any specs on it i need a starter asap..
I see them on ebay but which one to get?
Old Mar 25, 2007 | 09:05 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
summit has them. they are a multi mount design.
http://store.summitracing.com/egnsea...=KeywordSearch
take a look there are alot of hi po starters.
chazman
Aug 28, 2018 03:25 PM
Wade787b
Sep 29, 2015 01:15 PM
chazman
Aug 22, 2015 02:01 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 21, 2015 07:20 PM
