knock sensor
Old Mar 23, 2007 | 10:38 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
Axle/Gears: stock 10 bolt
knock sensor
i am new to the fuel injected engines and was wondering if i change mine to carborated it should eliminate my knock sensor right. becuase i would realy like to run some noisy timing gears.
Old Mar 26, 2007 | 03:55 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: knock sensor
Yeah, once you take the computer out, the knock sensor won't be able to send a signal to it to retard the timing.
Old Mar 27, 2007 | 05:47 PM
91blackrs's Avatar
Car: 91 camaro
Transmission: 5 sp
Re: knock sensor
ok thak you very much
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
