service engine light?
Old Mar 27, 2007 | 01:33 AM
85 camero's Avatar
Car: 85 berlinetta
Engine: 305 lg4 q-jet
Axle/Gears: stock going 3.73 posi
check engine lights on but no codes at all and i think 12 should flash .any ideas?
Old Apr 3, 2007 | 08:47 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: service engine light?
When you loose power to the ECM the light will stay on, and of course not flash since the computer isn't operatonal. I would expect the engine to run rough and use lots of gas if that's the case. Check fuses etc. Btw.; you did try the paperclip in the diagnostic plug thing?
Old Apr 21, 2008 | 01:41 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
What did you find out on this? I've got the same problem, no codes (not even the "12")....
Old Apr 24, 2008 | 03:42 PM
red406's Avatar
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
This happened to me. My car ran rich and ruff. I had a check engine light on and would not go off or flash codes. I made some calls and picked up a used computer and problem fixed. BTW. This was an all stock Z28 with cc Qjet.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
