Engine and Transmission selection...
Old May 17, 2007 | 03:28 AM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
Hi guys, I have an 86 IROC I'm planning to convert to carb. I had been optimistic about EFI and had originally planned to do a HSR but I've been thinking I want something that I can tinker with a little bit. Anyway, the car is getting a 350 and 700r4. The units in the car now are probably garbage so I'm going to eliminate them as a source of concern.
My question is, what engine should I pick up, and what transmission. The things I'm considering are an older longblock built by someone else, a Vortec longblock, a Longbock from a Camaro/Firebird, or an LO5 (least preferred choice). I know that older engines used a two piece rear main and that there are some differences in the transmission to accommodate. I have always assumed that you can't use a 1piece seal trans with a two piece motor or vice-versa. Is this part correct? I have been looking at late model 700r4s to make sure they got all the part upgrades and ensure that it will hold up for a while, but these are typically all 1-piece seal units right?
So basically what I'm asking is, if you guys were picking a engine/trans combo for a carbed setup, what would you look for? I'm trying to keep cost down as much as possible so money is a key factor.
I'm leaning towards the Vortec route at the moment but there seems to be a pretty good deal on some older engines in the classifieds and locally but are the late model 700r4s going to work with them or will I be stuck with an early 700r and if so are the early ones any good?
Thanks for your input!
I should really change my sig... Done
Old May 17, 2007 | 06:37 AM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: Engine and Transmission selection...
there is no difference. you can use a 283 from a 1955 sedan with a 700r4 from 1992 or a 4l80e from a 2007 1 ton for that matter. just get a decent deal on a motor and use a 700r4 since you already have one in it.
Old May 17, 2007 | 10:39 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Well, that's not entirely true. First, the 283 didn't come out until 1957, and second, they weren't properly drilled for the starter. But, other than that, you are correct - the rear main seal type doesn't affect whether a TH700 will work with a 350. You just need the proper type flexplate.
The '80-up blocks seem to be of higher quality than the earlier ones. So, that's one reason to go that route. After that, it's a matter of intended use and budget that dictates where you go. You could do any of the shortblocks with upgraded Vortec heads from sdpc2000.com, any of a number of aftermarket heads, 3rd gen heads, etc. Most any truck head, swirl port (LO5), and any 70's heads should be avoided.
Old May 17, 2007 | 10:52 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have a friend that just build a .060 over 350 with vortec heads. It is ready for a carb and accesories. He is located in London just off I-75 if you are interested.
It has new hyper pistons, its a 010 4-bolt block, vortec 906 heads that have been P&P clearanced for larger lift cams. The cam/lifters are new 292h cam. It has new roller tip rocker arms, double row timing chain, oil pump. It has a vortec rpm airgap style intake. The rings and bearings are all new.
PM me if you are interested.
Old May 17, 2007 | 11:44 PM
jaredi's Avatar
Car: 97 Z71
Engine: 350 Vortec
Thanks for the info guys, that bit about the transmissions being able to be used is a relief. I'll keep everyone posted as to what I end up doing.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
