Cant control Idle
Old Jun 5, 2007 | 09:02 PM
ztweny8's Avatar
Car: 82 Z28
Engine: SBC 350
Transmission: 700R4 w/Shift kit
Cant control Idle
I have a 82 Z28 with a 350 V8 (not the original, its a 78 block). The carb is a Holley Street Avenger 670 w/electric choke. I tried ajusting the idle screw, but it has no effect. I can turn it in almost all the way and it does nothing, and turn it out till it almost falls off and it has no effect. Should I be looking at the fast Idle screw? Im reading on Holleys website, but I need some more help.
Also, it seemed like the choke wouldnt turn off, because the choke light on the dash was on nonstop. But I unpluged the positive and negative wires going to the choke, and the light stayed on, so its probably just broken.
Old Jun 5, 2007 | 09:46 PM
89redliningRS's Avatar
Re: Cant control Idle
Might be to rich also. Check your idle mixture screws.
Old Jun 5, 2007 | 10:18 PM
DillonRager's Avatar
my holley did that i got a stronger return spring to pull it back and touch the idle screw then i adjusted the screw. just go to napa and get the biggest one and bend the ends to fit. hope this helps it worked for me
eightsixseven
Dec 16, 2024 01:50 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike40sm2
Sep 1, 2015 02:15 AM
Dialed_In
Aug 20, 2015 01:45 PM
