PCV Valve
Old Jun 14, 2007 | 08:44 PM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
PCV Valve
Hello guys,I was wondering if you can help.I installed a 1975 chevy 350 on my 1986 pontiac trans-am.I installed an edelbrock proformer intake and a 600 cfm carb.I was wondering if i can eliminate the PCV valve because i wanted to use a breather instead.
Old Jun 14, 2007 | 10:02 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: PCV Valve
pcv helps keep the oil cleaner, no reason not to run it.
Old Jun 14, 2007 | 11:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: PCV Valve
Keep the PCV. It will help keep harmful contaminants from condensing in your oil, and it won't vent so much oil vapour all over your valve covers.
Old Jun 16, 2007 | 09:26 PM
hotrod78's Avatar
Car: 1986 Trans-Am
Engine: chevy 350
Transmission: TH350
Re: PCV Valve
Thanks for your help
Old Jun 16, 2007 | 09:51 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: PCV Valve
you can get breathers with pcv valves built into them.
tyeo098
Nov 30, 2015 06:27 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
