runninng rich
Old Jul 25, 2007 | 09:30 PM
steve87iroc's Avatar
Car: 1987 iroc z
Engine: 355 dart platinum 215cc heads
Transmission: <<BLOWN UP TH400>>
Axle/Gears: 10 bolt 4.11's
runninng rich
i just got my motor together and running but im having a problem its running rich the spark plugs have carbon build up. they are brand new plugs and wires. the carb idle circuits are 2 1/2 turns out. motors in sig didnt have a problem with last motor stock 882 headed 350. any ideas oh ya i havent drove it yet or any high rpms could it be cause im just leting it idle
Old Jul 25, 2007 | 11:18 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: runninng rich
what is your tiing at? what type of carb are you running? what copression ratio does yourengine have? a lil more detail will help
Old Jul 26, 2007 | 12:05 AM
battyice's Avatar
Car: 1985 Z28
Engine: 355 topped with Dart heads
Axle/Gears: Stock axle with 3.73's
Re: runninng rich
How much advance are you running at an idle? Also, what are you using for spark plugs? I believe those heads call for an autolite AR133, a very cold plug.
I have an engine combo very close to yours, same heads and a very similar cam. Mine needs a lot of initial advance to idle decently, I also switched to a carb with 4-corner idle.
Old Aug 7, 2007 | 06:55 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Re: runninng rich
dude....2.5 turns out is way too much for the idle screws. on a holley it should be from .5 to 1.5 turns out. did you use a vacuum gauge to dial in the idle? should have the screws set for the highest vacuum at idle.
Old Aug 14, 2007 | 02:21 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: runninng rich
We have very similar combos... and I'm having the same problem you are. I think I personally need to just drive the car a little bit. I havn't driven mine either. Tonight I am changing plugs, fuel filter, draining my old gas, taking off the carb and cleaning it out. I think this should do it. What is your initial timing at? I run about 21 degrees initial, 34 degrees in by 2500 rpm. Also, what P.V. do you run?
Old Aug 14, 2007 | 05:50 PM
wdigitog's Avatar
Re: runninng rich
bump...
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
James Sutton
Sep 23, 2015 02:18 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
