electric to manual
Car: 92 Z/28
Engine: 322 ci sbc
Transmission: t-56
electric to manual
i have a 91 z that was a tpi car. i am about done building my new motor and it is a carb motor. my question is can the electronic fuel pump be modified to be just a pickup so that i can run a manual fuel pump on the motor. if so then if anyone knows what it takes to do it i would appreciate the info.
Corey
Corey
Transmission: 4L80E/4L80E
There are lesser ways, but that's the only right way to do it.
Your choices are a stock '82-'86 carb pick-up, or fabricate the tube/screen in your originally-electric pump pick-up.
Car: 92 Z/28
Engine: 322 ci sbc
Transmission: t-56
Re: electric to manual
thank you ill get the tank dropped in the next few days and hope that i can get this car on the road in the next month or so.
Car: 97 Z71
Engine: 350 Vortec
If I had it to do over again I believe I would buy the mallory 3 port regulator and be done with it.
You could also just buy a T fitting and run one end to the mechanical pump and one to the return line. This would provide you a very low pressure stream of fuel so the mechanical pump wouldn't have to work so hard and would also give you the return line to cool the fuel and it would be cheap to.
Pac J
May 17, 2020 10:44 AM
