quick power valve selection Q. thx
Old Jul 31, 2007 | 09:59 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Hey, how do you know if you need a high flow power valve or a standard one? My motor makes around 460 fly HP, around 350 at the wheels. I idle at around 6" of vac. and I have an out of the box 750 Holly DP. I hear these have 6.5s so my PV must keep opening. I want to get a 4.5 but am not sure if i should get the high flow one. What do you guys recommend?
Old Jul 31, 2007 | 11:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I can't say I know what makes a PV "high" or "standard" flow, but looking through the Holley numerical listing, the only application they use high flow from the factory is alcohol carbs.
Old Jul 31, 2007 | 12:10 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: quick power valve selection Q. thx
You lost 110 HP through your drivetrain?
Old Jul 31, 2007 | 01:04 PM
Engine: LS3
Well something like that. I am not sure since I never dynoed the motor. But I have bog parts on the car, they make more friction and have more rotating mass. The moser 12 bolt is HUGE. And the T-56 is also heavy and big. I also have an extra thick flywheel that needed to be custom made to fit the T-56 to the Gen I block. I have herd you lose like 20%-25%, so I guess more like 430, something like that. I dunno. I am also running a stock ignition and just tossed it all togeather. I got my MSD digi box, dizzy and coil yesterday, I should be making a bit more after that.
TheViper
Oct 7, 2003 01:51 PM
JCee
Sep 27, 2003 01:16 PM
nathan2003
Car Audio
Sep 22, 2003 03:55 AM
fast86z28
Sep 16, 2003 06:39 AM
Peg8687
Car Audio
Sep 26, 2002 06:43 AM
