question on throttle linkage
Old Jul 30, 2007 | 10:15 AM
madmatt92RS's Avatar
Car: 92 Camaro RS 25th aniversary editio
Engine: 305 tbi
Transmission: auto
what do i need to hook up the throttle and tv cable linkage? i swapped a 400 sb in going to use a old rochester off of a big block. the car was tbi before
Old Jul 30, 2007 | 12:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The stock carb TH700R-4 set-up used a bracket that bolts to the intake manifold. That would be the simplest solution, find one of those ('84-'87 305 q-jet).
You may be able to get the Holley p/n 20-95 bracket to work.
The big block q-jet may not have the right studs to mount the throttle and TV cables. Holley 20-38 (throttle) and 20-40 (TV) should do the trick.
Old Jul 30, 2007 | 02:21 PM
Engine: 305 tbi
Transmission: auto
Re: question on throttle linkage
what about this? will it work? http://store.summitracing.com/partde...5&autoview=sku
Old Jul 30, 2007 | 02:29 PM
five7kid's Avatar
It will probably work with a Lokar throttle cable. No help for the TV cable.
I don't like the return spring attached to the lower part of the throttle arm (one thing I don't like about the stock q-jet set-up). Puts all of the load of throttle cable pull and return spring pull on the back of the throttle shaft. Putting the return spring on the top of the throttle arm, where the cable is, better balances those forces, reducing wear.
Old Jul 31, 2007 | 12:56 PM
Engine: 305 tbi
Transmission: auto
Do you have summit part numbers for the holley parts you suggested? so i can order them
Old Jul 31, 2007 | 01:27 PM
five7kid's Avatar
Put HLY- in front of them.
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
squiggy2
Aug 9, 2015 09:30 PM
