How do I link up my choke?
Old Aug 17, 2007 | 10:50 AM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
I'd like to enable the choke on this Chevelle that my sister and I have recently inherited. Here's what I know about the car:
Non-matching numbers 396 motor
Holley intake
Edelbrock 500 (or 550) CFM Vacuum secondary carb
"Choke" **** on the dash that I believe is not connected to anything.
Roller tip rockers
It has "a cam" (idles at 1000 RPM when warm)
4 speed manual
Fun as Hell to drive
From what I can see, there is a choke flap, a bimetal spring near the intake to control it, and some missing linkage between the two. Can you tell from the pictures exactly which model of carb we have? Has it been discontinued? Can we order just the missing linkage, or would we have to order a new carb? I can load more pictures too.
Also, is 1000 RPM an appropriate idle speed? In the absence of specific camshaft profile data, is there any field method to determine best idle speed? This idle speed seems high, and there are no vacuum leaks.
Attached Thumbnails How do I link up my choke?-img_3151_6_3_1.jpg   How do I link up my choke?-img_3147_2_3_1.jpg   How do I link up my choke?-img_3148_3_3_1.jpg
Old Aug 17, 2007 | 03:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The choke cable bracket is circled in green. The line the choke cable makes is the magenta line. You may have to find a clip of some sort to attach the inner cable to the choke lever on the carb.
Old Aug 22, 2007 | 10:12 PM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
Re: How do I link up my choke?
Thanks for the help, kid, I can always count on your help. It will probably be a few weeks till I get back to the car. How does the choke cable connect to the bimetal strip? I suppose it'd make more sense to me when I can get my hands back on it.
Old Aug 23, 2007 | 12:31 AM
five7kid's Avatar
They don't. You either use a manual cable to operate the choke, or link the bimetal thermostat to operate the choke automatically. I don't think you can get a link from the thermostat to the carb, based on the photos you attached. So, hook up a manual choke cable.
Fanatic1074
Oct 3, 2022 05:57 AM
3rd gen money
Oct 11, 2019 09:57 PM
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
