What's the PV plug thread size
Old Aug 22, 2007 | 08:39 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Need to grab a bolt or something to block both PV's because I'm pulling right at the PV's vacum limit and I want to test blocking them off.
What is the bolt size and thread I need.
Old Aug 22, 2007 | 08:45 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: What's the PV plug thread size
don't block them off, a street car needs them. Fix the problem the right way. I run the 4.5 PV in my car with no issues
Old Aug 22, 2007 | 09:15 PM
Aaron91RS's Avatar
Car: RS
Not going to permanently but right now I need to test it and see if I can get it to run right first.
Will sit there and idle ok but loads up and dies after I try and move it short distances or even when I drove it a 1/4 mile it started out ok and then lost all power. Lucky to limp it home.
Closed all the idle screws and it didn't die and the vacum appears to be right around that 6 mark so I need to eliminate one more thing.
Need a thread/bolt size.
Old Aug 22, 2007 | 09:50 PM
xpndbl3's Avatar
Car: 1984 Z28
no idea they sell PV block offs but i'd imagine it's a vacuum leak somewhere if you can close the mixture screws. If not put in a 3.5 or 4.5 PV and just test it that way, they're only $8
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
Linson
Aug 21, 2015 02:12 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
