choke wont open
Old Aug 24, 2007 | 06:55 PM
Ryan2112's Avatar
choke wont open
i have a 84 Trans-am, 305 q-jet.
my choke light stays all the time but when the motor heats up the primary choke plate is wide open ... and the larger secondary choke plate is still shut.
its supposed to open (at lest when you rev it) to my knowladge. But even if you rev it the primary choke plate is wide open but the secondary dosent budge. any info would help alot.. im tired of my choke light allways being on.
Old Aug 25, 2007 | 01:54 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The secondary butterfly isn't a choke. It's an air valve, used to control the air/fuel going into the engine to keep it from bogging when you go wide open throttle.
The typical reason the choke light comes on is the alternator isn't putting out enough voltage. That's a good place to start looking. Could also be a bad circuit (wire/connection), or a bad choke relay.
Old Aug 25, 2007 | 02:37 PM
Ryan2112's Avatar
Re: choke wont open
i know theres a bi-metal strip and a electric heater, but is the choke circut tied into a coolant temp sencer anywhere? i know everything about fuel injection but i dont know much about carbs, anyone know of a good book i can read about q-jets?
Old Aug 25, 2007 | 04:17 PM
Ryan2112's Avatar
Re: choke wont open
okay.. so i was looking at it today and the fuse was poped, so i replaced it and the choke light went out. i am beginning to think this choke light has nothing to do with the actual choke but with the circut that turns the choke light on.
Old Aug 25, 2007 | 05:30 PM
five7kid's Avatar
It certainly doesn't have anything to do with sensing the operation of the choke itself.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
