Fuel Pressure?
Old Aug 26, 2007 | 01:15 PM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
Fuel Pressure?
Hi I've got a replacement type fuel pump running off the cam and a SUmmit liquid filled fuel gauge mounted on a Spectre fuel rail going to my Edelbrock 1806 avs carb. How can I tell my true fuel pressure after warming up and sitting at idle the needle moves (bounces?) from 2.5 - 3.5 I guess the average would by 3 psi but I don't know. Also after running for a longer time the psi apparently goes down to 1.5 or so. Is my fuel pump going bad or am I reading the gauge wrong? If my pump is ging bad what would you suggest, Better quality mechanical or electric with a regulator?
Old Aug 26, 2007 | 04:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like the pump is getting weak. Replace it with either a good quality stock replacement, or the Carter M6626.
Old Aug 26, 2007 | 05:00 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Re: Fuel Pressure?
Well, I don't know if this your problem but I had the same problem. I have a Stewert Warner elect fuel pressure gauge mounted in my car for my NOS system. I installed the sending unit just before the carb fuel inlet. I thought my fuel pump was going south so I did a pressure and capacity test (fuel pump tester) and everything checked out. So I removed the sending unit from the fuel line and noticed that the small hole in the unit was leaking gas. I shook the unit for quite awaile trying to remove the fuel. When I had all the fuel removed I reinstalled the unit, fired the engine and had 5# pressure. I think that the sending unit works on pressurized air rather then solid fuel. My sending unit is mounted on its side so I think that is the problem. It should be mounted upright to prevent fuel from entering the sending unit. Anyhow that is what worked for me.
Auggie
Old Aug 26, 2007 | 05:19 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
Re: Fuel Pressure?
oh well cant expect to much from a 20 dollar pump. anyway do you think i will need a pressure regulator after the pump since i've read that the Edelbrock carbs seem to by picky about fuel pressure?
Old Aug 26, 2007 | 05:25 PM
Auggie's Avatar
Re: Fuel Pressure?
Buy a fuel pump tester and and do the tests. It is real simple and you might learn something. Not a good idea to just throw parts at a problem. I have a stock L69 pump and it puts out 3 to 6# all the time. Paid $27 at NAPA.
Auggie
Old Aug 29, 2007 | 11:59 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
Re: Fuel Pressure?
I think I still have a return style carter pump around I was going to use it and decided to use my cv pump since it is rebuildable and use a return style regulator instead. I can check tomorrow if you are interested. If I still have it $20 and shipping it's yours
Old Aug 30, 2007 | 02:52 PM
five7kid's Avatar
Re: Fuel Pressure?
I wouldn't go that far. I've never had any problem with the Carter, or the stock AC replacement that preceeded it.
Shouldn't need a reg. I don't read everything available about Edelbrock carbs, but I've never seen that they're sensitive to fuel pressure.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
