Helicoil my intake?
Old Sep 16, 2007 | 02:39 PM
'86 350's Avatar
Car: '86 Camaro SC
Helicoil my intake?
I'm not sure if this would go here or in general engine tech, so a mod can feel free to move it. I'm running an Edelbrock Performer spredbore intake on my car right now. After removing my carb numerous times trying to find a vacuum leak along with tuning it, I seem to have destroyed all the threads in the intake (8 in all). I tried re-tapping it with a 5/16" tap, but to no avail.
My question is, can I just helicoil these with a 5/16" helicoil and be good to go again? Also, how exactly do I use a helicoil? Would I just get a drill bit that's one size bigger then 5/16" and then just bore out the hole, and then insert the helicoil and be done? What keeps the helicoil in place also?
-Thanks, Brandon
Old Sep 16, 2007 | 02:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Helicoil my intake?
Yes, you can helicoil the intake. Use the drill bit size specified in the helicoil kit to drill out the damaged holes, tap the holes with the supplied tap, and screw the helicoils in with the little plastic tool.
Old Sep 16, 2007 | 09:24 PM
'86 350's Avatar
Car: '86 Camaro SC
Allright, sounds good. One question, i'm looking at these at my local auto parts store, and their running me like $20-$30 for just enough to do like 6 holes. Does that seem right?
Old Sep 16, 2007 | 10:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Sounds about right. Mostly you're paying for the tap.
Old Sep 16, 2007 | 10:15 PM
'86 350's Avatar
Car: '86 Camaro SC
Allright. Thanks for your help.
Old Sep 17, 2007 | 10:16 AM
'86 350's Avatar
Car: '86 Camaro SC
One last question. It's kinda unrelated, but I figure there's no point in making a new thread for a fairly easy question.
I'm picking up a 650DP and it's going onto my Edelbrock intake. The intake is spreadbore, but the carb is squarebore. I have a 1" open adaptor to go from a squarebore carb to a spreadbore intake, but whenver I run it I either seem to get a vacuum leak from it, or the low-end is just kinda sucked outta the car. It pulls nice at the higher rpm's, but with the cam in this car it's already kinda hard to drive on the street, so if I can i'd like to not run the adaptor.
Will I run into a vacuum leak or any problems if I don't run the adaptor?
Old Sep 17, 2007 | 11:37 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Are you runnin the gaskets with the adaptor. This will cure your leak if not
Old Sep 17, 2007 | 11:43 AM
'86 350's Avatar
Car: '86 Camaro SC
I am running the gaskets with the adaptor. Another reason i'm going with the 650DP is because it's mechanical secondaries as opposed to vacuum. Since my car is a manual, I was told it'd be much better for my application.
I've tried replacing the gaskets to no avail, I'm probably just gonna try to pick up another adaptor and see if that's the problem.
Old Sep 17, 2007 | 11:48 AM
Car: 91 Camaro RS
Engine: Small Block
I've had a similar problem like this before, and thats why i was asking. I was using a metal spacer. but since switched to a plastic one to dissipate the heat, and it didnt leak anymore.
Old Sep 17, 2007 | 11:50 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Which intake are you using?
Old Sep 17, 2007 | 12:22 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
An open spacer on a dual plane intake can ruin your low end. You want a 4 hole spread bore to square bore adapter. pep boys sells a spectre brand one, that is aluminum on the outside but uses a plastic (phenolic) spacer in the middle.
Old Sep 17, 2007 | 01:03 PM
'86 350's Avatar
Car: '86 Camaro SC
Edelbrock Performer intake. I'm running a 3/4" Mr. Gasket open adaptor to fit the spread bore intake.
This one: http://store.summitracing.com/partde...5&autoview=sku
Damn, I just spent like $25 on this adaptor a few months ago too.....
Old Sep 17, 2007 | 01:06 PM
Car: 2000 BMW M5
Oh he's using a Performer (not rpm). That is already a dual pattern intake. You do not need any adapter to bolt a square bore carb on it. Edelbrock sells a thin 1/4" spacer to help prevent leaks when using a square bore carb, but I have run that intake w/out it many times with no problems. Ditch that $25 spacer, and get a new square bore gasket, and mount it up and go.
Old Sep 17, 2007 | 01:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yeah, you'd only need the adapter if you were trying to put a squarebore carb on a 4 hole spreadbore manifold, like a stock one. I like using the thick (3/8" or so) gaskets, rather than the thin (1/32" if that) ones.
Old Sep 17, 2007 | 03:09 PM
'86 350's Avatar
Car: '86 Camaro SC
Cool, sounds like a plan. I'll just pick up a thicker gasket at autozone and run it.
-Thanks, Brandon
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
