Edelbrock avs 650 running slight lean at idle and really lean at just off idle/cruise
Old Oct 11, 2007 | 06:56 PM
project86ta's Avatar
Car: 86 TA
Engine: 305 carb
Transmission: 700 R4
Axle/Gears: Not Sure
Hey guys what would cause the below condition..... I have 19" vaccum at idle screws 2.5 turns out silver springs 98 primary jet with a .065x.047 rod and 95 secondary jet. I am using an autometer gauge with an edelbrock 02 sensor one in each bank and both are pretty consistent with each other.
Edelbrock avs 650 running slight lean at idle and really lean at just off idle/cruise more so when it warms up
Old Oct 12, 2007 | 06:08 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: Edelbrock avs 650 running slight lean at idle and really lean at just off idle/cr
if its just lean at idle and part throttle change your rods maybe try a .063x.047 or go to a .100 main jet and put in the orange springs so it doesent richen up till you have the throttle cracked some more...
did you actually tune it with the vac guage or did you just turn it 2.5turns out cause thats what the manual says to start at after a rebuild?
Old Oct 12, 2007 | 08:30 PM
Car: 86 TA
Engine: 305 carb
I got it new and went out 2.5 turns to try to get it to read stoich on the a/f monitor at idle but no luck. I didn't figure it would do any more good to go out farther than that. I don't have a smaller cruise rod so I'll probably have to go up a jet size.
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
