will i notice a difference?
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
will i notice a difference going from a 600 cfm edelbrock to a 650 cfm holley dp? both are used with a fresh rebuild. check the sig for my set-up.
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: will i notice a difference?
with that cam and a low stall converter i would stick with the edelbrock for the vac secondarys... if you have over a 2800stall then get the holley.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I would go with the double pumper no matter what. It will make more power than the edelbrock would and be easier to tune as well.
edelbrocks are not vac secondaries. the are called "air valve" mechanicle sec. with another flap above the throttle blades to somewhat meter the incoming airflow.
