fuel leak problem in holley carb
i have a holley 600 vac secondarys that i just rebuilt but now gas is blowing back out of the air tube thing one the blow cloest to the firewall why is this happing? and what do i need to do to fix it?
Transmission: 4L80E/4L80E
Most likely the float needle isn't sealing against the seat. Typical causes are dirt, not assembled properly, not adjusted properly.
Re: fuel leak problem in holley carb
i agree, i had the same problem with my demon and it was because the needle/seat was jammed open; i replaced it with a new one and it worked great. good luck
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
600, 650, blowing, carb, carbs, carburator, carburetor, carburetors, fuel, gas, holley, holly, leak, leaking, leaks
