q-jet ok.
Old Oct 15, 2007 | 07:45 AM
230 firebird's Avatar
Car: 1987 pontiac firebird
Engine: sbc 350
Transmission: TKO 600 5 speed
Axle/Gears: 323 posi/disc from 86 gta
q-jet ok.
I am installing a 350 in my firebird which came from a 89 chevy van.I bought a qjet carb for $25 off of a late 70-early 80 cutlass.Will this carb work ok? I dont know how to tell what the CFM is.I am having a freind rebuild the carb also.John
Old Oct 15, 2007 | 11:56 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: q-jet ok.
89 Chevy van, that's probably a TBI engine. You'll need to get a spreadbore intake manifold. If money is tight, just grab a stock intake from a V-8 3rd gen Camaro/firebird.
Other than that, yea, the carb will work fine. It's a quadrajet, so it flows 750cfm, simple as that.
Old Oct 20, 2007 | 04:38 PM
Engine: sbc 350
Re: q-jet ok.
Thanks for your help
Old Oct 20, 2007 | 11:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What distributor were you planning on using?
Old Oct 28, 2007 | 09:19 PM
Engine: sbc 350
Re: q-jet ok.
I am using a vacume advance distributor out of an older GM car?
Old Oct 28, 2007 | 09:35 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: q-jet ok.
That should be OK.
69GTOby
Apr 18, 2016 02:34 PM
BumpaD82
Feb 26, 2016 02:57 PM
NZKnight
Oct 15, 2015 02:47 PM
BWilcox
Sep 20, 2015 12:19 PM
pacoelrapido
Sep 11, 2015 02:41 PM
